how to hook up fpss??
Old Sep 26, 2005 | 06:02 PM
93camaroLT1's Avatar
Default how to hook up fpss??
I bought a EFI fuel pressure safety switch from cold fusion, which came with no instructions. Looking at it I got an idea of how to hook it up, but i'm not too sure I want to be playing guessing games. So, how do I hook this up exactly? Also, is this FPSS adjustable? How do I check and adjust it after I install it?
Old Sep 26, 2005 | 06:23 PM
White98Z's Avatar
is it 2 prongs i would just hook it up on the signel wire coming from the window switch to the relay.
XTrooper's Avatar
Thread the FPSS into a manifold and thread the manifold directly to the inlet side of your fuel solenoid. The white relay wire (when using an NX relay) goes to the NO-marked (normally open) terminal of the switch and the NC-marked (normally closed) terminal goes to ground unless you're using an rpm window switch. In that case, connect the ground wire from your window switch to the NC terminal of the FPSS.
Yes, it's adjustable. Remove the rubber plug from the top of the switch and turn the allen head screw clockwise to increase the pressure setting and counterclockwise to lower it. They're supposed to be set at 35 psi from the factory, but the only real way to check is with a fuel pressure gauge.
Old Sep 27, 2005 | 01:33 PM
Matt@HSW's Avatar
Send me a PM with your email address. We have a set of instructions that I can email you.
Matt
