MSD window Install. help me out.
Old Sep 30, 2005 | 06:49 PM
FloridaZ's Avatar
Default MSD window Install. help me out.
I have everything wired up right. white one is going to pin#10
When i turn it on it flashes "On". I push mode and it reads Zero. When i let go it goes back to "ON". An ideas? Do i have a bum Switch or am i just retarded
Old Oct 1, 2005 | 07:54 AM
FloridaZ's Avatar
-ttt-
Old Oct 1, 2005 | 09:39 AM
XTrooper's Avatar
Are you pushing the mode button multiple times to "scroll" through the mode options?
Is the unit reading your engine speed like a tach? It should be.
Old Oct 1, 2005 | 09:59 AM
FloridaZ's Avatar
it's not reading any rpms
i'm tapped into #10. I even double checked my connection. I put a test light on the wire right next to the box and it pulses a signal.
Old Oct 1, 2005 | 03:57 PM
XTrooper's Avatar
Something is wrong then. You should put the switch in 4-cylinder mode for it to operate correctly (provided you can).
