Thinking of doing nos
Old Oct 3, 2005 | 08:23 PM
mrhzk35404's Avatar
Default Thinking of doing nos
I have a stock 01 t/a m6 with pacesetter headers and magnaflow catback with the tsp catted y pipe. What is recomended for a stock drivetrain? any part numbers and what would I need to do to the car like a new fuel pump ect.
Old Oct 3, 2005 | 08:42 PM
Matt@HSW's Avatar
With your mods I would say you could do a 100 - 125 shot. I would suggest upgrading your fuel pump, and if you do a 150 shot isn’t out of the question. I look at fuel pumps as cheap insurance. Some other safety things to pick up would be a window switch, a fuel pressure safety switch, and a set of colder plugs, like some NGK TR-6s. If you go with a wet kit look into picking up a bottle heater too.
Matt
Old Oct 3, 2005 | 09:04 PM
NitrousDirect's Avatar
You could do a standard wet kit or you could go the direct port route. You're fine up to about 150hp then you need to start looking at fuel pumps.. but I do have customers running more than that on stock. You don't NEED anything but i would suggest a fuel pressure safety switch. Please let us know if you need anything at all.
mrhzk35404's Avatar
is there a certain kit I should look at?
Old Oct 3, 2005 | 09:18 PM
pm'd ya but either an ls1 wet kit or the direct port kit depending on your budget and needs
