New product....
Old Oct 7, 2005 | 12:56 PM
CAT3's Avatar
Restricted User
Got it, replied and will be ordered one way or another by next week. Also, if you happen to drop a -4 bottle nut in the box that would be great...I didnt see the new bottle didnt come with them Its full, but cant use it unless Andrew's bottle is empty!).
Old Oct 23, 2005 | 10:34 PM
Nitro Dave's Nitrous Outlet's Avatar
LOL,
Yes it makes it hard to use with out the bottle nut and nipple.
Dave
Old Oct 24, 2005 | 12:15 AM
Azhigher's Avatar
And another part hits the wishlist lol.
Very Nice!
Old Oct 24, 2005 | 08:28 AM
LT99LS1's Avatar
By built in TPS, does that mean I do not have to have a micro switch mounted on my TB?Do you have these in stock?
Old Oct 24, 2005 | 08:58 AM
Yes, The TPS takes away the microswitch. These are instock.
Dave
Old Oct 24, 2005 | 10:42 AM
860 Performance's Avatar
Just installed on of these on an 05 GTO. It worked great and was easy to install/program. I'll get some pics up soon.
Thanks again Dave.
Old Nov 2, 2005 | 03:22 PM
to the top
Old Nov 2, 2005 | 07:19 PM
scalemaster's Avatar
Hey Dave I might get 1 next week so save me 1 ok this will be good with my new systems
Old Dec 27, 2005 | 01:52 PM
pianoprodigy's Avatar
Default MSD Digital Window Switch - Which wire to which pins on relay?
I'll be installing my MSD digital window switch tonight. I know I need to use a relay. Which wires go to which pins on a traditional relay? Nitro Dave is closed, or I would call and ask him.
Thanks.
Old Dec 27, 2005 | 11:03 PM
Wow. I know its late so hopefully someone helped you. If now here you go.
On the relay.
Pin-86= accessory hot
pin-87= to solenoids
pin-85= grounding wire from windowswitch ( not Chassis ground)
pin-30=12 volt positive
Hope this helped.
Dave
