Anyone spraying 300 or more?
Do that and you have made an effective combo that will spit out some good HP #
Let's say I make 800HP @ 6,000 RPM and you make 800HP @ 9,000 RPM. Assuming the cars are geared properly and such, which one is faster?
The 9,000 RPM car would accelerate faster because it could take advantage of a bigger gear.
Benji...you obviously have a point your trying to make
Just share what your thinking..lol. I would love to hear it.
My answer to the above would be tha same as the previous example. I dont have enough info to make the call. I would need to see the full graph and not just the peaks if these are real motors.
Well...what if that 9000 rpm car was a 1.8 liter honda with a giant turbo that doesnt spool until 8500 rpm , made 800 hp at 9000 rpm and dies off at 9500 rpm? Or a peaky 347 with a badly made sheetmetal intake manifold doing the same thing.
And what if the 6000 rpm motor was a masterpiece and made 800 hp right at 6000 rpm but carried that HP (tq at rpm
) out and it still made 750 hp all the way out to 8000 rpm?There isno way to tell with these examples IMO just talking in terms of peak HP
If you took an air tight room that was 5'x5' and filled it up with air and you took a room 15'x15' and filled it up with air, which would have the greater pressure of the 2?
Am I wrong?
Robert
800HP @ 6,000 RPM = 700 FT. LBS.
800HP @ 9,000 RPM = 467 FT. LBS.
Let's say that for any give estimated MPH and tire size, the 6,000 RPM engine needs a 4.56 gear. Because the 9,000 RPM engine turns 50% more RPM, it needs 50% more gear, or, a 6.84 gear.
700 x 4.56 = 3,192 FT. LBS.
467 x 6.84 = 3,192 FT. LBS.
This is why, in my opinion, HP is HP is HP, no matter the RPM you make it at.
Pressure * Volume = number of molecules * ideal gas constant * temperature
assuming that everything on the right side of the equation is the same, as volume increases, pressure has to decrease, and as pressure increases, volume decreases. If Pressure stayed the same, and volume increased, then the right side of the equation would have an increase.
basically, larger cylinders will require less pressure to make the same power.
Adam
Adam
If the horsepower curve was perfectly linear for both motors, then your statement would be true. It really has to do with area under the curve.
If a 9000 rpm motor had exactly 1.5 times the area under the curve as the 6000 rpm motor and the gearing was perfectly matched as described earlier, then both motors would accelerate the 2 cars evenly.
