NX 100 shot = 50 rwhp???
Originally Posted by fastbasser
Steve,
I was making some humor! This was dynoned almost at sea level. I see you are from PA. Are you going to the Corvette Challange on 10/22 at Englishtown?
Vinnie
Vinnie
I'd love to go to one of these sometime, but it's a long drive just to have my *** booted off the track after my first run. I not only don't have a roll cage, but I drive a convertible!
Originally Posted by sbcgenII
100 shot is a 100 shot good one! Anyhow how much torque did you pick up with the botttle. It may have something to do with the convertor to.
I'm in the same boat. My plan is to use my first 2 runs to figure how to get some traction and run to the 1/8th mile marker and back off.
If I can hook up on the 3rd run, keep her wot and see what happens.
I would expect with "reasonable traction" to be an unwanted visitor!
Would like o put her to bed "knowing" what it will run.
P.S.- If you plan you use your Nittos, air them down to ~16 psi and REALLY heat them up. If I do a short burnout, I never hook well.
The NX guys do this as a job, not a hobby/passion like us normal gear heads.
Try the .028 and see if it's better, you'll feel it if that's it, and it's not a big enough change to hurt anything. So you have a before and after dyno print out?
Robert
Robert
Robert,
I didnt get a dyno sheet on the nitrous run because I didnt ask for one. I wasnt there for a n20 dyno run. Just did it out of curiosity.
I will email the guys and see if they can email me a copy. That won't be until monday though.
When I get it, someone is gonna have ta show me how to post it.
Thanks
Thanks
Weather and/or air density "should" not effect the nitrous part of the run. That's why I went to it instead of a supercharger. My car does not care about outside temp when I am on the juice as much as a supercharged car does. My air temp is cooled by the juice, not like a supercharger that has to pull in hot air. So I don't believe outside temp is a real factor for this problem. I personally would check the items I listed first BEFORE playing jet doctor. Better safe then sorry. I hope some of the NX guys jump in here and shed some light on the low numbers. As you said "2 for 2" low, I have "3 for 3" normal. Very strange.
You did get the medical grade nitrous, that way if the numbers aren't there you can just inhale it!!!!
Someone has to have a real answer....
Thanks for all the info guys. Here is my plan...
1) Check to make sure there is no blockage near the jets.
2) I'm going to swap out plugs to a plug not so far on the cold side. (these plugs, AR12, are real cold and I was trying to be "over" safe. Will go to a "reasonable plug, AR23. (note, I can not run standered length plugs in my heads. They have been macined to take a shorter reach (.300 less) plug) If some can cross a TR& or such to a plug like this, let me know.
3) Swap to the 28 fuel jet.
4) Get the bottle to 1050.
5) Hope all stays together.
Will try and get it dynoed at a local shop. (One I have never been to!)
This of course ONLY if this freakin rain stops !!!!!!!!!!!!!!!!!!!!!!!
I will post results.
Thanks
PS... I use medical grade nitrous!
Thanks
I have read/heard that a big stall will affect Hp/TQ when it comes to using N2O. If this is a false statement someone please speak up.
I had to use different jets (other than the chart) to get the 100 and 150 to the rearwheels.
If you have a problem with your NX instead of complaining about it in a post, try a PM to NXRicky or call NX and see what they say. They have some of the best customer service. You might also try Nitro dave
30thz,
It is my right to make post about something I have over $1500 invested in and it DOESN'T do what is advertized..
Tell me, When you buy a kit, it doesnt come with a warmer. (That package was another $300 and yes I bought it) How would you get 1050psi without it?? Aint gonna happen .. SOOOOOOOOO..
How would you get 100 on a 100 shot with 900psi?? (That was my bottle pressure after it was filled yesterday..
HMMMMMMMMM
HMMMMMMMMM
-somebody
Somebody,
Sorry,,, As a member of this board I have as much "right" as anyone else to post what I feel is problem with something I have spent serious money on. I am not using profanity as many others do. I am stating facts, not fiction and answer other peoples post as respectfully as others answer mine.
Please understand,, As I said in a previous post, I will make adjustments to my setup to try and see if things change. In all honesty, I should not have to. You should get what you pay for.. Plain and simple..
Only those who have their cars dynoed really know if the get what the pay for..
JMHO
JMHO
JMHO
JMHO
Don't get rapped around dyno numbers, especially when it comes to nitrous on the dyno. I had a dyno tech tell me everything from my bottle pressure was to low, my trans was going to **** ( and that was the day after I got it back from being rebiult) and when I took it to another dyno it was nothing more that a simple jet change. Not all dynotechs know what they are doing.
You have to remember not all cars are the same. Fuel pressure, bottle pressure all this effects the hp/tq. Good luck with it and keep us update you have me curious to know what it is.
Originally Posted by 30thz
I believe it should be "Only those that run their cars at the strip really know if they get what they pay for.."
Bottle pressure can make a big difference on the dyno and at the drag strip. NX systems are designed to be used at ~1050 psi. Spraying at 900 psi will deleteriously affect output and performance.
My car only did a 50 shot on 100 shot, but my motor was in the process of blowing up when I dynoed, so it wasn't an acurate number. When I get a new 346 in there next week I will dyno it again and post results.
BTW, I normally dyno 383/400+ RWTQ/RWHP and have run several 7.15's at 95 mph in the 1/8th and 11.42 at 122.58 MPH in the 1/4 Mile and that was on a poor 60'. Dyno Queens never tell the true story, but the track will.
There is somethign wrong, that's for sure. 100 shot should give you 100 shot, or close to it.
Good Luck
Good Luck
The kit alone will not get the advertized power. Do you feel this is an accurate statement?
And by the way, I totally agree the track is where numbers are put to rest!!
It's a basic kit. The GenX1 And GenX2 are upgrades to the vehicle specific kits. Not everyone uses a heater some use pusher system. One thing to remember is the base kit doesn't come with safety equimpment either but it's a smart thing to add.
Yes, to your statement the Basic kit alone does not come with everything need.
