Nitrous bottle in C5 compartment
This all fit under the top cover.
Its kinda tough to describe but what I did was take 1/8"x1.5" steel and bend 2 of them up to span across the pocket. You can see one of them near the bottle valve. The other thing I had to do was to take the bottle apart and modify the draw tube since the bottle needs to lay sideways, otherwise the blow down tube would stick up too high.
Hope that helps.
Vinny
The picture is kinda dark, but the steel bracket is seen kinda behind the blow down tube in the picture.
