Will this Cam work good for a 100 wet shot
Old Oct 31, 2005 | 04:25 PM
Odessastangslayer's Avatar
Question Will this Cam work good for a 100 wet shot
ok i am about to buy this cam and i was wondering if it would be ok to run a 100 shot wet with this, the cam is Comp Cams 222/224 .566/.568 112 lsa comp XE lobes, will this cam have any bad impact when i spray the shot to it or will it be ok, lots of people have said this is a small cam (i dont know that much about cams when it comes to picking one for nitrous use so any input will help greatly thanks alot guys
Old Oct 31, 2005 | 08:37 PM
brad8266's Avatar
It is a faily small cam even though the LSA is low. It will work fine with nitrous. Any cam will work with nitrous, it seems that nitrous works greatest with a cam that has more exhaust duration than intake duration. Choose your cam for what you want running N/A, since thats what you will be running with most of the time. ****, a stock cam works fine with nitrous.
Old Nov 1, 2005 | 02:42 PM
sounds great thanks for the input and i will be running this cam very soon (realy stoked)
Old Nov 1, 2005 | 02:52 PM
MosesMcgregor's Avatar
i have that exact cam and love it. I run a 60 dry shot and the torque and hp gains are about equal. N/A i put out about 390+hp / 370+tq and with the juice was about 450 /430. I have GMMG and long tubes and the lope and sound of this cam is awsome, i get props all the time for it. The car is my daily driver and i think it is very livable.
Old Nov 1, 2005 | 03:50 PM
thats good to hear thanks alot, that was the only thing that woried me and now it doesnt so thanks alot guys and im sure i will love the sound of it
hz28's Avatar
What about Hot Cam? is too small? i will be adding juice to this cam...
Old Nov 2, 2005 | 09:07 PM
ZeroTraction's Avatar
MosesMcgregor -- do you pass emmissions just fine with the cam you have? im in the merket for an LS1 and i will be addin a cam, just not sure what one yet! i will be also addin an nx wet 35-150 kit to it, but i have to keep the cam on the mild side.....i want to have zero problems with emmissions.....also will i have to get a tune with this cam?
Old Nov 2, 2005 | 09:31 PM
Matt D's Avatar
Retired Street Racer
Anything under a 150-175 shot isn't gonna matter. When you go more than that, you should get a purpose built nitrous cam.
Old Nov 3, 2005 | 12:27 AM
I dont know if i pass smog.
I wouldn’t run it without a good tune, especially if you are gonna juice it too. you can get away without a tune but the drivability will be ****, it will surge pretty bad and will be fun when warming up.
