Heads/Cam and a Wet shot?
A) You would or would not do it?
B) If yes, how would you set it up, and how much?
Thanks for any and all input
Drew
You should be able to spray up to a 150 shot with no trouble. Someone correct me if I'm wrong...
The motor should be able to take it no problem. The rear end however, may need to be upgraded to a 12 bolt or 9" (depending on how you drive and if yo go to the track or not).
