few ? on a DRY system
Also, one of my noid sticking open issues was with a filter. When I tore it apart it was from moisture. Cleaned it up, and been working since.
Noids do occasionaly stick open and/or fail to open. All kits and companys have a certain failure rate.
Robert
LOL,Ok so your point is that adding a second solenoid on a dry system is needed for safety. You say that doing that on a wet system just adds more risk. How is that it adds more risk? The whole purpose was incase one of the nitrous solenoids stuck open. So wouldnt it serve the same purpose on a wet system. Using dual nitrous solenoids. What if the system had a nitrous solenoid stick open after the system was turned off. How can it serve one purpose on one set up and not the other.Other than the fact it is a waist of money and time .Not to mention the huge restriction it causes.
On a dry system if the solenoid stuck open for some reason.You will know.The car will act funny.But want the maff add the fuel needed? Hopefully the indavidual will have enough common since to pull over and turn off the bottle. Unplug the coil packs and turn the motor over cycling all the nitrous out the exhaust.
For the guys reading this. Robert and I are not argueing. We are having a technical discusion...
Dave
These are someone elses pics, but i did this too, works good, cant find anything, Ran line in wire loom, cant see a thing under the hood.
If you know the signs of a stuck solenoid IE surging when the blade is closed, if your bottle is mounted like mine you kill the system and turn the bottle off which is mounted right behind you...
Ok Ok call me over cautious but when your one noid goes, wave bye to your bottom end because it will be on it's way out too.
Dave
Robert
Dave
heard this single nozzel can spray up to a 175 dry shot
Dave
Robert
Your just a dumb *** probaly 14 15 y/o just here running your mouth like in other threads. Why don't you go and race Longrange4U rather than tell him I might beat you! Damit mites live on chickens ***. Either you will or won't Chicken ****.
Who said you were a rookie? You did b/c you are! Ok so after a launch, still rollin down the road you turn your attention to make 2 full twist to shut off your bottle? I stand proven you are a Dumbass!
Robert
Dave
Dave
Dave
Did I read that correctly, NX in the dry?
Robert
Robert
Dave
Robert
NX has 1 dry nozzle already, 1/8 npt thread, and are coming out with a 1/16 pipe thread one also..
Black for that nice clean look.
But at this time NX has NO intentioins of building a dry kit. sure we have the incognito kit, but I would not call that a dry kit,,, MORE of a grouping of parts, OR a kit that is missing something...
Ricky
Dave
Mike
