Dry Kit users
Old Nov 24, 2005 | 11:22 PM
BrianC98Z28's Avatar
Default Dry Kit users
I had a couple of questions. I am leaning more and more towards this. For dry kits is it not as important to have a bottle heater as it is with a wet kit? Also what about a purge for a dry kit is it not needed? I am just wondering since I am more familiar with wet kits then I am dry. Also Robert56 check your p.m's
Brian
Old Nov 25, 2005 | 12:46 AM
code4's Avatar
Brian
No, the pressure is not as important because the amount of fuel to be added is adjusted by how much nitrous is flowing through the maf. I would recommend a heater for cooler weather as it is hard to keep the bottle up to any decent PSI. My bottle will get down to 600 PSI. I like spraying at 1000 PSI, so a bottle heater is a good thing. Lower PSI = less nitrous. A purge will get the nitrous right up to the solenoid so there is no delay when you need it. Also it can be a good thing to bleed off PSI on a hot day.
Old Nov 25, 2005 | 01:18 AM
Robert56's Avatar
gotcha
Robert
Old Nov 25, 2005 | 08:32 AM
BTLFEDSS's Avatar
I run a heater on my set up just to get higher bottle pressure
BTLFEDSS
