Bolton Nitrous Guys
Old Nov 26, 2005 | 12:40 PM
BrianC98Z28's Avatar
Default Bolton Nitrous Guys
What kind of e.t's are you seeing and what size shot are you spraying? I am at 12.0 right now and was considering spraying 100 shot and that theoretically should net me some low 11sec e.t's. I was just wondering what the boltons & nitrous guys are running.
Brian
Old Nov 26, 2005 | 12:45 PM
charlie c5's Avatar
If your in the low 12's right now, then with a 100 shot you could easily drop 4 to 5 1oths. off your et. The faster you are on motor the less a 100 shot will take you. If you were running 10s, then a 100 shot may only drop your et a 10th or 2.
Old Nov 26, 2005 | 12:47 PM
setxws6's Avatar
If you keep up the good 60fts, you should be in the lower 11's with a TNT 100 shot. And a 150 shot and a really good 60ft, could get you in the 10's. I would recommend TNT of course, but NX is a good brand as well. Just remember to have a good tune, tires, and suspension.
Old Nov 26, 2005 | 01:17 PM
Cheater's Avatar
with your setup (witch is nice) you should go 11.6's or so depend on how hard you are and if you spray off the line
Old Nov 26, 2005 | 01:22 PM
GM Muscle's Avatar
With a 1.60 60' and a 3350lbs race weight, it took a TNT 150 shot to put me in the high 10.90s with just bolt ons.
Old Nov 26, 2005 | 01:31 PM
Cheater's Avatar
ok GM Muscle what did it run on motor??
Old Nov 26, 2005 | 01:46 PM
GM Muscle's Avatar
No clue, I have yet to make an N/A pass.
