Will this window switch work on LS1
Old Nov 27, 2005 | 02:31 PM
corvettelover's Avatar
Default Will this window switch work on LS1
Will this window switch work on LS1? Thanks for all the help.
http://store.extrememotorsports.com/...cfm/4,711.html
The site looks like it for Mitsubishi's, but I'm figuring it will work with any car.
Also, if this won't work, could someone tell me were I can find a good cheap one, as I'm limited on cash right now (Christmas).
Old Nov 27, 2005 | 04:43 PM
Screamin_Z's Avatar
u need to find out if it can read 4 cyl engines, if it does then I'm sure it will work
Old Nov 27, 2005 | 05:01 PM
This is what I found during a google search.
http://www.centuryperformance.com/ma...wRPMSwitch.pdf
It seems to me like it will work. Could someone please verify? Thanks for all the help.
Old Nov 28, 2005 | 11:14 AM
Nitro Dave's Nitrous Outlet's Avatar
have not seen one of the mallory units so I do not know anything about them. However check out or Trick winowswitch. I see you have a vette. This window switch is a dual window switch with any gear lock out feature and a built in TPS whick will be great in your case.
http://www.nitrousoutlet.com/outlet/...section_id=137
Dave
