Need some nitrous help
Old Dec 3, 2005 | 12:52 PM
rosm187's Avatar
Default Need some nitrous help
i have a 2004 gto, actually picking it up in a week or 2 and the first thing i plan on doing is nitrous, i want to get an NX wet kit, and am looking at the maf kit, or the dual stage. im just a little fuzzy on what extra things i need, i.e bottle heater, guages? and im pretrty sure i'll be getting a window switch, any advice is appriciated.
thanks
Old Dec 3, 2005 | 01:25 PM
383LQ4SS's Avatar
What are your goals HP wise? The MAF kit is tough to beat. The install appearance and quality is second to none. I would recomend a window switch for sure as well as a heater. Id consider that the bare minimum. The gueges I like to have are fuel pressure and nitrous pressure. if you can only afford one get the fuel pressure since you can get a less expensive nitrous pressure gauge to go on the bottle. But its nice to have both right in your face when you need them.
A purge will help with the wet kit as well
Also dont forget to change out the plugs to some NGK TR6 or equivelent. I belive they come gapped at .038 and that will be sufficient.
Im not sure what comes in the GTO's but a fuel pump upgrade may also be in order depending on how much total HP you intend to make. Maybe some GTO guys will chime in on what they are up to with the fuel system.
check out this linkhttps://ls1tech.com/forums/nitrous-oxide/416742-christmas-specials.html and look at Nitro Daves special on group 2. Thats a complete dual nozzle kit with just about all the accesories for a pretty damn good deal.
Old Dec 3, 2005 | 11:11 PM
rosm187's Avatar
yea i was looking at that, with the heater and window switch for 9xx, i will spray 75-125 or 150 for now, but once i get a driveshaft and fuel system i hope to hit 200, i wantted the maf kit, but that dual stage kit will be good enough for me i think, anyone else? which kit would be safer, idont want anything to go wrong cause i would not be able to get a new motor asap.
thanks
