switched 12 volt power ?
Old Dec 5, 2005 | 01:11 PM
oange ss's Avatar
Default switched 12 volt power ?
any place under the hood I can get switched 12+ ? thanx
Old Dec 5, 2005 | 02:46 PM
Matt@HSW's Avatar
If it's a F-Body (or most other GM vehicles) the pink wires are switched 12v. You can double check with a voltmeter and try to avoid overloading the circuit.
Matt
Old Dec 5, 2005 | 02:48 PM
SS ONE's Avatar
check the fuse box under hood there is a switched fuse there its the mini fuses
