Zex mounting
Old Dec 6, 2005 | 07:31 PM
GuesDog's Avatar
Default Zex mounting
Where should I mount the Zex Box? I need some ideas kinda stumped with space issues, show me what you got. I have a 99 Ls1 T/A, ws6 lower air lid.
Old Dec 6, 2005 | 08:29 PM
2LATEULOSE2's Avatar
I don't have any pics but I mounted mine in between the battery, the backside of the battery
Old Dec 7, 2005 | 12:44 AM
2002LS1Z28's Avatar
dont have any pix either but on my camaro i mounted between the driver side strut and the fuse box....right below the sticker on the body...it might be different for you though
Old Dec 8, 2005 | 12:57 AM
Caribe's Avatar
I have mine mounted underneath the fuse box.
Old Dec 8, 2005 | 08:19 PM
GuesDog's Avatar
Ok so I mounted it on the drivers side in front of the shock tower by the fuse box and by the power terminal. It looks good and I made my own switch panel where the TCS is on the T/A I took a piece of hard board painted black, drilled some holes put them in and called it done. It looks really good I'll try and get some piks up later when I get the purge hooked up correctly, its being a PITA, well the tube that is.
