Nitrous On An Automatic
Old Dec 7, 2005 | 10:07 PM
edlt1's Avatar
Default Nitrous On An Automatic
With nitrous on an automatic should you let off of the nitrous during shifts? Since the throttle body is always at WOT during shifts.
Thanks
Ed
Old Dec 7, 2005 | 10:34 PM
DevonsZ's Avatar
Use a window switch and that will take care of your spray/shift problems. *You can set rpm points for the system to spray between with a window switch. Like on at 3800rpm off at 6000rpm. etc..*
Old Dec 7, 2005 | 10:38 PM
NXRICKY's Avatar
Closed ex-Sponsor Account
with a good tranny and/or small shot let RRRRRRRRrr Rip... But keep your window switch to stop the nitrous from spray if you happen to hit the limiter...
Ricky
