how much can a bolt on lt-1 take
Old Dec 8, 2005 | 02:18 AM
steez's Avatar
Default how much can a bolt on lt-1 take
ive been looking at a nx 125 shot wet kit for my bolt on 94 i should be able to spary all dya no problems right any advice/help would be greta thanks i advance...wiht all the sfaty features window swtick fss ect ect what should a good kit run me cdn
Old Dec 8, 2005 | 10:16 AM
Nitro Dave's Nitrous Outlet's Avatar
The stock bottom end can safely take a 150 shot.However I like to suggest upgrading your intank fuel pump for anything over a 100 shot. The two best saftey features are a windows witch and fuel pressure safety switch. A bottle heater will help maintain the bottle pressure needed for the system to fuction propery. A purge will empty air out of the line and help you get a better sit off the line. PLuss it can purge down bottle pressure if needed. The nitrous pressure gauge is needed to know your bottle pressure. A NHRA valve and blow down tube will be needed to pass tech at the race track.
For your set up a simple NX or Nitrous Outlet Single nozzle kit will still give you the best quality available at a affordable price. If you are looking for something more custom I suggest one of our plate systems or a NX maff kit. For the accessories a GENX2 is the best way to go.WE carry many different window switches also. Give us a call or PM for cheaper pricing than what is listed on the web site.
Dvae
Old Dec 8, 2005 | 11:04 AM
TwoFast4Lv's Avatar
As Dave said you should be very safe with a 100 shoot. many run a 125-159.
Back in the Day When Kurtis Tamez was selling NX stuff he ran well over a 175 shot pushing a completely stock engine and transmission to 11.45. I would not recomend this at all
I will have to talk to Ryan K and see what the limits of the MAF kit where when he was testing it for NX
Old Dec 8, 2005 | 11:53 AM
steez's Avatar
awsome thanks guys, i just want to be able to run a 100 shot all day with out screwing around to much wiht the timing ect ect and i want it to be safe and reliable
Old Dec 8, 2005 | 01:36 PM
Ellis,
The maff kit can easily flow 250HP per side. The system out of the box can flow 200.00 and 250 with upgrading the hose from the solenoid to the maff plate.
Dave
