harlan 2-step wiring question
Old Dec 27, 2005 | 06:53 PM
Turo's Avatar
Default harlan 2-step wiring question
I posted this in the drag racing tech ection, but I figured I'd give it a shot here also. I'm planning on wiring my 2-step to deactivate my nitrous kit like on this diagram:
Question 1:
What size relay am I supposed to use? I can get 5-pin 30/40 Amp relays locally, will those be ok? BTW, my nitrous kit uses a 40-amp relay, if that matters.
Question 2:
On my nitrous relay, pin 86 goes to the WOT switch. What about on the Harlan relay? What exactly is a "12 Volt Micro Switch"?
Old Dec 27, 2005 | 09:55 PM
NXRICKY's Avatar
Closed ex-Sponsor Account
1. Needs to be at least 30amp..
2. 12 volts switch would be like a transbrake button or just any button you want to activate your two step..
Both being a 12 volt hot source when activated.
Ricky
