FJO Progressive questions
Old Jan 2, 2006 | 09:25 PM
70Stang's Avatar
Default FJO Progressive questions
Ok, here are a couple questions I have about the FJO Mini controller...some will sound stupid, some may not...but I am looking for some clarification!
1. If I set it to time based and have the time be 1.5 seconds starting at 25% and ending at 100% will the nitrous then stay on after the 1.5seconds?? Like, for the rest of the run? Or do I have to set the time to be 11.5seconds to get me thru the whole run?
2. On the LS1, does the TPS Rise or Fall?
3. What RPM Multipler do you use?
4. What is the NX Solenoid frequency?
THANKS!
Old Jan 2, 2006 | 09:58 PM
Black X's Avatar
This is the information I have maybe someone can just confirm this.
1, Yes it will stay on after the 1.5 seconds. If you have the final percent at 100% The time portion only controlls the ramp.
2. TPS on the LS1 will rise.
3. On the LS1 you use Divide by 2 because it is a waste spark and fires on exhaust stroke as well.
4. As per NX Ricky use 14HZ or 16HZ for the Larger NX Noids.
Hope this helps.
Old Jan 2, 2006 | 10:33 PM
70Stang's Avatar
Awesome!
Old Jan 2, 2006 | 11:56 PM
NXRICKY's Avatar
Closed ex-Sponsor Account
Black X is right on the Money..
Ricky
