Can I safely do a 300 shot?
MOTOR: 408 CI Stroker (11:1 comp), bore-4.030"-6.0 iron block, stroke-4.00"-Eagle crank
Diamond pistons w/ 2cc valve relief, Eagle 6.100" rods
236/242 .598/.610 114+4
Patriot Stage 3 LS6 heads, 38# injectors, Shaner S3 TB, LS6 intake, SLP Lid, Hooker LTs, true duals w/ XR-1s
DRIVETRAIN: Strange 12 bolt, Strange 373's, B&M Ripper Shifter, Spec Stage 4
SUSPENSION: Lakewood LCAs
POWER ADDER: NX EXPRESS wet kit with TNT F1 power ring jetted at 200
Can I safely go 300?
I would recomend either one of two things to do it right.
One...is to upgrade your injectors if needed and then get a nice dry kit such as Daves Halo ring to spray a 125 shot at say 3000 rpm. And then have your TNT power ring bring in another 175 or so at around 4500-4800 rpm. That way you only have 175hp worth of fuel flowing down the intake and it will be at higher rpms. Use either a dual stage window switch or the dual stage NX/FJO mini controller with that.
The second would be to go direct port. You could sell the kit you have now...or parts of it. You could keep the bottle and just get the direct port kit minus bottle. The prices on these are more reasonable than you may think. But keep in mind cost of plumbing the direct port if you arent going to do it yourself.
).Robert
