Fpss??
Old Jan 5, 2006 | 10:24 PM
codewhitfield's Avatar
Default Fpss??
Where do you mount a FPSS on a Dry kit? I just don't have a clue where it goes!
Old Jan 5, 2006 | 11:32 PM
z28viperkiller's Avatar
directly to the fuel rail schrader fitting with the core removed. You need a fitting that connects to the fuel rail shrader fitting that converts to the fitting for the fuel pressure safety switch. On the ground side of my solenoid relay it is connected. It was important to me to adjust the switch to turn off after after dropping below 56psi. It really isn't a real on and off switch. A few psi are required to make a clean cut in resistance. within about 5 psi , my switch varies the resistance..(stock NOS) with experimentation, I calculated the exact psi when the relay turns off the solenoid. I hooked up a test light on the power side of the nitrous solenoid, taped it to my windshield and had a fuel pressure guage hooked up to the fuel rail and taped it to the windshield, when in tesing. The FPSS [U]MUST be fine tuned for your setup.
Old Jan 6, 2006 | 12:52 AM
Thanks man...I gotta get that fitting.
Old Jan 6, 2006 | 08:07 AM
WS6HUMMER's Avatar
Got mine 2 days ago with the FPSS from Harris Speedworks. I think together the fitting and the FPSS cost me 35.00
Old Jan 6, 2006 | 10:41 AM
Nitro Dave's Nitrous Outlet's Avatar
Code,
Part number 15718 comes with a manafold.If you have the switch but no manafold you need a part number 15506. You will also need a -4 cap to cap off the end of the manafold.Its a part number 16144.
Dave
Old Jan 6, 2006 | 11:33 AM
WS6HUMMER's Avatar
Originally Posted by Nitro Dave's Nitrous Outlet
Code,
Dave
Do you stock these parts dave? I looked on your web sight but counldnt find the FPSS just the fitting.
