Nozzle problem, Please Help
Old Jan 11, 2006 | 08:09 AM
WS6HUMMER's Avatar
Default (pics)Nozzle problem, Please Help!
After taping my maf I realized (once I bolted the maf back together) that the maf itself was in the way of the nitrous line.. Will using a different brand of nozzle mean my Cold Fusion jets might not work? What's the differance between a soft plume fogger nozzle and a Pro Fogger nozzle? I welcome any reccomendations whatever nozzle I use I'd like to try to stay with 1/16th size. TIA
Hummer
Old Jan 11, 2006 | 10:00 AM
WS6HUMMER's Avatar
What about this nozzle, is it 1/8 or 1/16?
90016 Nitrous Express SHARK/PRO-SHARK/SUPER SHARK NOZZLE
Old Jan 11, 2006 | 10:16 AM
Nitro Dave's Nitrous Outlet's Avatar
Yes the shark nozzle will give you more clearence.
Dave
Old Jan 11, 2006 | 10:22 AM
WS6HUMMER's Avatar
Dave
Thanks Dave, what size are the nitrous and fuel connections? I think my lines are 3 AN.
Old Jan 11, 2006 | 11:13 AM
DynotuneN2O's Avatar
LS1TECH Sponsor
You will need NX jets to work with that nozzle as jets are not interchangable.
Dan
Old Jan 11, 2006 | 11:38 AM
NXJeremy's Avatar
WS6HUMMER - replied to your pm.
Old Jan 11, 2006 | 11:51 AM
WS6HUMMER's Avatar
Thanks!
Old Jan 11, 2006 | 11:53 AM
WS6HUMMER's Avatar
Dan
Thanks also Dan
Old Jan 11, 2006 | 12:06 PM
Somebody09's Avatar
What about having it welded shut and starting over? It's $50/hr for Al welding around here. Or, if the bolts line up, what about rotating everything else (in the front) by 90 degrees? I'm not sure though. I don't even know where my stock MAF is anymore.
-somebody
Old Jan 11, 2006 | 12:09 PM
WS6HUMMER's Avatar
-somebody
Thought about it.
Old Jan 11, 2006 | 12:19 PM
383LQ4SS's Avatar
You can buy a .90c NPT plug at home depot to plug that side and tap the other side. Just be sure to use some thread sealer on the plug so its perfectly sealed.
Old Jan 11, 2006 | 01:14 PM
WS6HUMMER's Avatar
Yeah I have an extra set of stock ends, think I'm gonna use one and drill and tap the other side. I'll have to move all my noids though, I live I learn.
Old Jan 11, 2006 | 03:11 PM
Robert56's Avatar
That's what I would do, just move to the other side as Al suggested. I sure like the nozzles mounted in the maf rather than the bellows, much tricker looking, nice job.
Robert
Old Jan 11, 2006 | 03:14 PM
WS6HUMMER's Avatar
Robert
Thanks, I can only afford to swap to the other side. It really costs to install nitrous the right/safe way.
Old Jan 11, 2006 | 03:21 PM
ws6sojuiced01's Avatar
You could also look in to thiss nozzle from HSW (Back Mamba)
[QUOTE=WS6HUMMER]After taping my maf I realized (once I bolted the maf ]back together) that the maf itself was in the way of the nitrous line.. Will using a different brand of nozzle mean my Cold Fusion jets might not work? What's the differance between a soft plume fogger nozzle and a Pro Fogger nozzle? I welcome any reccomendations whatever nozzle I use I'd like to try to stay with 1/16th size. TIA
Hummer
[/QUOTE
Old Jan 11, 2006 | 03:39 PM
WS6HUMMER's Avatar
[QUOTE=ws6sojuiced01]You could also look in to thiss nozzle from HSW (Back Mamba)
Hummer
[/QUOTE
Thanks, I'll check it out.
Old Jan 13, 2006 | 12:41 AM
NEVR2ND's Avatar
Turn the MAF so the box is downwards, and drill and tap the same side. Also NOS makes a nozle that fits in that side, it has the flat end by the MAF box.
Old setup
Old Jan 13, 2006 | 08:06 AM
WS6HUMMER's Avatar
I ended up putting the nozzle on the passengers side, now my lines from the noids to the nozzle are too short.
