ZEX c5 Install TPS wire
http://www.nitrousexpress.com/Instructions/1pcmaf.pdf
IF you put it on the pedal and traction control is on your throttle boey will close and that would not be good.
Ricky
See, it always helps to get a second set of eyes, it's been a little bit since I've done a C5. Always double check your signal too...with a voltmeter.
"yes...thank you for calling N.E.X., how may i help you.....oh, the TPS wire? ...just hook that puppy up to your gas pedal! yep...works for Honda, Toyota and Mitsu-shi-shi"
Dave
