What controller/switch?
Old Jan 14, 2006 | 09:04 AM
kokki's Avatar
Default What controller/switch?
I have searched and I have no idea what kind of switch or controller should I have.. I would have 1st gear lockout, and when armed I want to have nitrous working at wot between 3000 and 6000 rpm, and after that one shot, I want to be able to push button to be not armed anymore, or if I will not press button then armed with some time delay..
Situation will be like 1/4 mile or topspeed competitions.. Does that FJO's 2 Stage TPS and RPM Window Switch be enough? Or should I have wot switch, timedelay switch, and rpm siwitch? I like the idea to have one box..
Old Jan 14, 2006 | 11:49 AM
NXRICKY's Avatar
Closed ex-Sponsor Account
Get with Nitrous Outlet the switch he has will do it, and the on or off thing is just adding another switch in series with a wire, No biggy. let me know which one you get and I will help you wire it up.
Ricky
Old Jan 14, 2006 | 04:42 PM
kokki's Avatar
How about that Timing tuner? Should I use that to correct my timing? I will use nitrous quite rare, so is that easiest way to handle that timing or how could I do that?
Old Jan 14, 2006 | 05:17 PM
383LQ4SS's Avatar
How much HP are you looking to make? what size shot.
I personally would get the FJO/NX dual stage. It will do everything you want to and then some. For highway racing rpm mode pregressive is unbeatable for safety and max HP.
Old Jan 15, 2006 | 03:03 AM
kokki's Avatar
I think that 100 HP should be enough.. Ok, that 2 stage is not so expensive, like $206, I will try that software with it..nice configuration, that you can adjust parameters with your PC, no dips or that stuff..
Old Jan 15, 2006 | 01:59 PM
Dragframe's Avatar
with a 100 shot you shouldn't have to even worry about you timing
