NX jet question
Old Jan 18, 2006 | 10:19 AM
1BAD02WS6's Avatar
Default NX jet question
iv tried searching for links but no matter what i put down for it to search for i get "no matches found"
Question is..what pills does NX use for a 150 shot? im using a 52n 32f right now and that netted me 90rwhp and 150rwtq (bit of a spike) but i want to up to a 150.
also id like to know what the 125 jets are?
Thanks for your help.
Tyler
Old Jan 18, 2006 | 10:36 AM
NXJeremy's Avatar
100 = 52N 28F
125 = 57N 33F
150 = 62N 35F
You're more than likely only getting 90hp on the 100hp setting because the fuel jet is way to big. Use the jetting above and you should see the full 100hp to the wheels. Let me know if I can help with anything else.
Old Jan 18, 2006 | 05:51 PM
purple98haz28's Avatar
i the nitrous jets the same for a dry shot? and same hp gain?
Old Jan 19, 2006 | 09:23 AM
NXJeremy's Avatar
Purple98haz28 - If you are using our nozzle, solenoid, etc. then yes the nitrous jets should be the same for the given hp settings as long as you have the correct amount of fuel.
Old Jan 19, 2006 | 06:43 PM
thanks i have a dry kit i made outta everything nx...solenoid, nozzle, bottle etc
Old Jan 19, 2006 | 07:01 PM
garth285's Avatar
hey do you know what jet sizes .046N and .026F are for? I was told a 75 shot but not to sure?
