Nitrous cutting OUT!!!
If while testing the relay sounds like it has a bad ground.
Ricky
well i got low bottle pressure and a small leak and alot of people are saying that low psi causes surging- and i will move the seat up farther- also the zex bottle mounts i think are a little low im gonna put a mount on the bottom of the front one to set it up a little higher- also im gonna replace the leaky fitting and get the bottle warmer and blanket on there and run 1000psi and see what happens then-
If it's not a leak...It still "sounds" electrical by your description. There really arn't that many places that you need to check. I really suggest that anyone who messes with electrical use a multi meter to check voltages. Maybe draw out a schematic of exactly what you have scan and upload it somewhere to be seen...it will benefit you and us to help you troubleshoot your system.
sorry i resized it but photobucket isnt regestering it-
heres the deal-
i ran the truck this morning on a 75 shot and it worked good the first two times then it started cutting out again- so i go home check all the grounds and recrimp everything and put them back- then tonight i try to spray and it wont spray at all- i had the switch turned on half a bottle of nitrous and 890psi- so do yall think its the msd window switch f'n up on me?
heres the deal-
Robert
Robert
like this?
http://www.msdignition.com/rpm_7.htm
Robert
