Which TPS and window??
Old Jan 20, 2006 | 10:15 PM
fastlt1's Avatar
Default Which TPS and window??
Which TPS and window switch to get? Are the TPS really worth it or just use the one that comes with the kit?
Old Jan 21, 2006 | 11:29 AM
fastlt1's Avatar
So is a TPS switch overkill?
Old Jan 21, 2006 | 11:36 AM
DynotuneN2O's Avatar
LS1TECH Sponsor
I would go with this window switch. It also has a built in TPS and multi gear lockout. The advantage with the TPS is typically a cleaner install as you do not need to use the WOT switch.
http://www.dynotunenitrous.com/store...?idproduct=194
Dean
Old Jan 21, 2006 | 02:13 PM
fastlt1's Avatar
It says something about two stage. Could you elaborate?
