Who mentioned to shift earlier when Spraying???
Old Jan 29, 2006 | 11:40 PM
CAT3's Avatar
Restricted User
Default Who mentioned to shift earlier when Spraying???
I forgot who posted, and I even inquired about it too *banging head*, about shifting earlier when spraying, as the nitrous makes more torque the lower the rpm is etc.. I tried it and it seems to work nicely. I will have to do some comparison runs, but so far, I think I may have found the sweet spot....by accident of course.
Sorry for not recalling the SN, but my searchs suck. Thanks for the info.
Charlie
Old Jan 30, 2006 | 01:21 AM
chpmnsws6's Avatar
hey man, whatever works! glad to hear you shaved over a second off your previous best!
Old Jan 30, 2006 | 07:12 AM
Noyzee's Avatar
8 second mod
not sure if i said it, but i did it and it worked very well. i was shifting at 7200, and ended up at 6400
it worked much better
Old Jan 30, 2006 | 09:41 AM
white2001s10's Avatar
that was me.
I'm glad to hear it helped you out guys!
Old Jan 30, 2006 | 09:43 AM
CAT3's Avatar
Restricted User
white...thanks, and yes it seems to be working quite well. I figure for *****-n-giggles I will run one or two shifting in the old NA rpm range, and then comparison can be made a little more accurate...but damn does it pull much stronger by SOTP.
Old Jan 30, 2006 | 04:17 PM
Loudmouth LS1's Avatar
Holy ****, that's a huge diff, I was shifting 7200 on motor and then went 7000 on spray.
Old Jan 30, 2006 | 04:21 PM
Noyzee's Avatar
8 second mod
i went from 7200- 7000 it went faster, so i went to 6800 it went faster, so i went to 6600 faster, 6400 i broke the record!!!!!!
but keep in mind i was only 346 ci and had a very mild cam
Old Jan 30, 2006 | 04:28 PM
True, but what do you consider mild? I'm not much more cubes, just mildly stroked which should actually take away some rpm from my understanding, it's a 374 (3.905 bore x 3.900 stroke) and i'm running a fms hydraulic roller cam with specs of 246/257 .632/.645 112+4. So what you think, should I try lower next time out?
Old Jan 30, 2006 | 04:36 PM
Noyzee's Avatar
8 second mod
hydrolic cam, try 6800
my old cam was in the 230's and 580's thats it. it was mild!
Old Jan 30, 2006 | 04:41 PM
Damn, that was a pretty mild cam! Thanks for the recommendation, once I get everything sorted out so I can make a full pass, i'll try 7000 first to see where she's at and then drop to 6800 and see what happens.
