i have bmw e30 m3 nos kit installed
Old Feb 4, 2006 | 01:37 PM
shekom3's Avatar
Default i have bmw e30 m3 nos kit installed
hi guys i really like your site it is really great and full of informations
i have an e30 m3 s14 320is 4 cylinders bmw universal n2o (nos) kit installed 1 fogger i dont know where to put my fogger to give me the maximum power of nos my shots is the 75 bhp shot
note: i put my foger at the end of the air-flow meter but it didint gave me the power i need so i put it on my airbox but i still dont like it where should i put it please help !!!
my engine: s14 320is 4 cylinder & it have 4 throttle bodies
http://www.badongo.net/pic.php?file=...age(104)23.JPG
http://www.badongo.net/pic.php?file=...Image(124).jpg
here in my country we don't have the direct port kit so i used this kit
Old Feb 4, 2006 | 02:12 PM
APeteSS's Avatar
It's a wet kit right? I've seen good results with the wet nozzle in the cold-air tube, but I don't know if you could seal it up properly if you made a hole in that rubber intake tube for it.
Old Feb 4, 2006 | 03:36 PM
shekom3's Avatar
thank you for answering me this question is too important 2 me , i cant make a hole in the rubber bec. it is very flixable i am thinking about making a stainless steel tube instead of the rubber tube and make a hole in the stainless and put the fogger in it am i right & what do you think about my idea ?
should the space between the fogger and the throttle bodies became close or far from the throttle 2 give me the max power and i want my engine to be on the safe side
Old Feb 5, 2006 | 01:49 PM
APeteSS's Avatar
I'll have to check some materials I have here for more info, but I thing you have a good idea to replace the stock plastic air tube with a stainless tube that you can weld/seal the fogger into. As I said before, I saw a great setup on a Hyundai 2.6 V6 where the fogger was about halfway up the stainless cold air tube so I think you're on the right track.
How did the car respond when the nozzle was in the airbox? Did the car lurch and hesitate?
Old Feb 5, 2006 | 01:59 PM
hondo's Avatar
lets try this....
what was your bottle pressure when you were spraying?
what is the fuel pressure NA? does it take a dive when you spray?
what jets are you using?
Is the big red box on top of the TB's just an empty plenum? or is there a filter in there?
Old Feb 5, 2006 | 05:04 PM
white2001s10's Avatar
Originally Posted by hondo
lets try this....
I agree, you need to answer those questions before we could really help.
Also make sure your nozzle is pointed in the right direction since it's a wet kit.
Low power is usually a case of running way too rich.
Old Feb 5, 2006 | 07:32 PM
JonathanE30///M3's Avatar
Most wet kit installs that I've seen for the e30 S14 motors have the foggers tapped into the airhorns that mount to the throttle bodies. Its a more expensive setup naturally, and requires proper tuning to keep from grenading that pricey S14. I would try to find a shop local to you that is experienced in running multiport fogger systems. You can also try www.s14.net for some help, they're mostly anti-NO2, but there are some very knowledgable S14 gearheads on there that might be able to help you.
