new to N2O
Old Feb 7, 2006 | 10:52 AM
ELMiN8oR's Avatar
Default new to N2O
i'm new to nitros, i'm just wondering
whats the diffrence btween Wet and dry N2O.
if any one have any pictures i will thank you aloot
Old Feb 7, 2006 | 11:09 AM
camaross305's Avatar
a wet shot is used with a nozzle that mixes gas with n20 before entering your motor. Where as a dry shot is just n20 that is sprayed in your motor and uses your cars normal fuel supply. only difference is with a dry shot you will have to upgrade your injectors where as depending on the size of the shot both will require and upgraded pump.
Old Feb 7, 2006 | 11:18 AM
ELMiN8oR's Avatar
ok can you tell me where do they place them in the engine ??
i mean how do i install them ?
Old Feb 7, 2006 | 11:31 AM
it depends there is many different ways....alot of people with a dry shot install them in the lid....with a wet a single nozzle can go in the smooth bellow. Also with wet there is plate kits, maf kits, direct port etc. really depends on how much u wanna spray and your goals.
http://cgi.ebay.com/ebaymotors/LS1-C...36296279QQrdZ1
thats is a good example of a good spot to put a dry shot
there is tons of wet examples all over here
Old Feb 7, 2006 | 11:34 AM
white2001s10's Avatar
It's explained in the FAQ above about 2/3 way down the page. Wet vs Dry.
https://ls1tech.com/forums/showthread.php?t=140389
Old Feb 7, 2006 | 11:58 AM
Old Feb 7, 2006 | 12:06 PM
ELMiN8oR's Avatar
is that TNT wiring for LS1 ???
Old Feb 7, 2006 | 12:14 PM
N20LS1's Avatar
Wet kits are easier on the engine (less chance of going lean). A good wet nitrous kit is the TNT F1 OR F2.
Old Feb 7, 2006 | 12:38 PM
ELMiN8oR's Avatar
ok Stock LS1 engines (intake, headers, cat-back) with hypertech programmer A4
whats the maximum nos shots i can give it to this stock motor ??
Old Feb 7, 2006 | 12:47 PM
Until exactly what happens?
That's a very vague question. Some people go 200 and 300hp or more on stock engines.
A 100hp shot is a good place to start if your new to N2O.
Old Feb 7, 2006 | 12:53 PM
ELMiN8oR's Avatar
which one is the best in quality and in performance: (TNT, NOS, NX, ZEX) ????
sorry for the disturbing but i'm new to N2O
Old Feb 7, 2006 | 01:17 PM
For the most part a 100hp shot of N2O is just that no matter if you buy your system or put it together yourself. Most differences in kits are just bells & whistles so it comes down to personal preference which bells you want.
One of the companies has a simple & cheap dry shot for about $300 which I'd suggest is a good place for you to start. Once you know more what you want, then just simply add-on or upgrade from there.
You've got an automatic so you have the simplest way to go. You don't need any extras at all really, so anything is better than nothing. As long as you start off at a reasonable 100hp level then you could use kits from any of those companies.
Some people like more bells & whistles but when it comes down to it they don't add any power. A 100-shot is a 100-shot.
Old Feb 7, 2006 | 01:29 PM
ELMiN8oR's Avatar
i'm sorry but what are bells and whistles
i'm new to nos.
and i only know that they call this round thing with "NOS" written on it is " Battery" and thats about it
Old Feb 7, 2006 | 02:28 PM
ELMiN8oR's Avatar
and about the 100 dry shots
do i have to change the fuel pump and injectors or it doesn't matter ?
