will inline work with 150?
Old Feb 7, 2006 | 12:11 PM
camaross305's Avatar
Default will inline work with 150?
if i get a walbro 255 lph pump inline will it work with a 150 shot? does it just go somewhere in the fuel supply and work along with my stock pump? or should i just spend the extra 150 and get a racetronix kit?
Old Feb 7, 2006 | 12:38 PM
GM Muscle's Avatar
The inline would probrably get the job done just fine but an intank is preffered. The inlines usually mount between the stock fuel pump and filter. I personally think the intank is worth the extra time and money because you will will still have the stock pump choking the system with an inline, that may limit you down the road.
Old Feb 7, 2006 | 04:33 PM
ok...yea i wasnt sure if i had to drop the tank or not but if i do im just going to go with a racetronix kit
Old Feb 7, 2006 | 04:36 PM
ill probly just spray a 100 shot for now until i can afford the pump
Old Feb 7, 2006 | 04:45 PM
GM Muscle's Avatar
You will not have to drop the tank for the inline. You can leave the tank in and cut an access panel to do the intank but it will make wiring up the Racetronix hotwire kit alittle tougher.
