which is the best spark plugs for nitrous
Old Feb 7, 2006 | 02:28 PM
charles clark's Avatar
Default which is the best spark plugs for nitrous
i have been told 5 different plugs for ls1 100-150 shot
Old Feb 7, 2006 | 03:49 PM
SmaknaSS's Avatar
TR-6's are very common with nitrous, I dont know if they are the best but a lot of knowledgeable people use them.
Old Feb 7, 2006 | 04:29 PM
foshizl's Avatar
Im using NGK TR-6s with 150 shot, they are 1 heat range colder than stock... seem to be holding up well have shot about 10 times on these plugs, and they still look ok
Old Feb 7, 2006 | 05:41 PM
Airwolf's Avatar
I have been using the Denso Iridium IT20 Plugs for some time and am very happy. They smoothed the idle out over the TR6. If cost is a factor go with the TR6's, they are much cheaper then the Iridium plugs. There is a NGK Iridium my friend (02 Pewter LS1) has been using with great sucess for a while and they are "in-between" the cost of the Denso and the regular TR6. I believe a few of the forum users are using them too. Hopefully they will chime in.
Just make sure you don't use Platinum plugs.
Old Feb 7, 2006 | 06:31 PM
brad8266's Avatar
I just replaced my TR6's after about 15 bottles through them and about 10k miles. They are a good nitrous plug, most people that use nitrous will tell you that as well.
Old Feb 7, 2006 | 10:11 PM
Josh@PremierAutosports's Avatar
I run tr6's with a 250 shot but my try one stage colder.
Old Feb 7, 2006 | 10:40 PM
1BAD02WS6's Avatar
im using TR55 iridiums on a 150 shot no problems yet
Old Feb 8, 2006 | 12:50 AM
thanks for the help
