February Nitrous Specials!!!
Old Feb 8, 2006 | 11:24 AM
Nitro Dave's Nitrous Outlet's Avatar
Default February Nitrous Specials!!! EXTENDED
We know that its hard to stretch your income tax refund as far as your wants and wishes. So here at Nitro Daves we have put together many different packages to help it stretch alittle further.
These specials are good until the first March.
You will need to call your order in at 1-866-648-7637
Group 1
Our Custom Dry GTO Halo system..
GTO Dry Halo,10 lb bottle with 45 valve,20 foot main feed line,Stainless steel quick release bottle brackets,300 hp Lifetime warrenty solenoid with purge port,all fittings, hoses and hard ware.
NX automatic bottle heater,purge,fuel pressure safety switch,nitrous pressure gauge,NHRA valve and blow down tube.
Our Trick digital window switch with built in TPS and any gear lock out feature. (will controll 2 stages)
NGK TR6 Spark plugs...
Special price 859.00
Group 2
Our Custom Dry F-body Halo system
F-Body Dry Halo,10 lb bottle with 45 valve,20 foot main feed line,Stainless steel quick release bottle brackets,300 hp Lifetime warrenty solenoid with purge port,all fittings, hoses and hard ware.
Group 3
Our Single Nozzle Dry System
Group 4
Our Dual nozzle Dry system
2 Dry nozzles,10 lb bottle with 45 valve,20 foot main feed line,Stainless steel quick release bottle brackets,300 hp Lifetime warrenty solenoid with purge port,all fittings,hoses and hard ware.
Our Trick Digital Window switch with built in TPS and any gear lock out feature. (will controll 2 stages)
Special price 825.00
Group 5
Nitrous Express single nozzle wet system
NX complete stage 1 EFI system
Special price 959.00
Group 6
Our Custom LS1 plate system...
Your choice of stock or 90mm.
billet plate,o-ring gasket,throttle extention bracket,jetting from 50-200,10lb bottle with 45 valve,stainless steel quick release bottle brackets,300 hp lifetime warrenty solenoids with purge port desighn,all mounting hard ware,hoses and fittings..etc
Special price 1,075
Group 7
Our Famous Dual nozzle special..
THE DUAL NOZZLE SPECIAL.....
This system comes complete with.
1.10lb Bottle With NXs 45 degree Valve)
2.Dual Shark Nozzles
3.High Flow Ys(because Ts are restrictive)
4.Blow Down Tube and NHRA Blow Off Fitting.
5.Liquid Filled Nitrous Pressure Gauge.
6.Iceman Pure Flow Solenoids (LIFE TIME WARRENTY)
7.Jetting From 100 to 300 Horse Power.
8.All lines,Fittings,micro switch,wiring harness and relay etc.
To top this all off we are giving you a free replacement Bellow too put your dual nozzles in.The Shark Nozzles come with adapter nut fittings that will firmly fasten the nozzles to the bellows.The bellows has no holes in it.All you have to do is drill two small holes where you like them.Place the nozzles and go.
This system has the best of the best.No fitment issues!!!! No headaches to make it fit!!! This is one of the best deals we have put together..
This complete system is going for 599.99. With this system we GIVE you for FREE a new smooth bellows (50.00 Value)
IF YOU HAVE A CORVETTE OR LT1 AND DO NOT NEED THE BELLOWS.Subtract 50.00 for your price
Group 8
Misc Discounts
1.BMN window switch with first gear lock out... 100.00 while supplies last.
2. All of our dedicated fuel systems have 40.00 off...
3.10 percent off our custom console switch panels and solenoid brackets.
Do to not having time to post March specials we are extnding these specials until the end of March.
Thank you for all your support.
Dave
Old Feb 8, 2006 | 02:23 PM
00formLs1's Avatar
any chance of a discount on the ls1 plate conversion?
Old Feb 8, 2006 | 02:47 PM
ls1408cp's Avatar
how about something for the carb looking victor jr... I know a lot of these are being used now i am one of them. twin gemini would be nice with all the accesories.
Old Feb 8, 2006 | 04:24 PM
Hennytime's Avatar
discount on bottle pressure gauge that mounts on the bottle
Old Feb 8, 2006 | 04:33 PM
redbullapril23's Avatar
i need to buy 8 nozzles whats the best deal i can get? i just ordered a fjo controller from yall! cant wait to get it
thanks your friend
Sean Blanton
Old Feb 8, 2006 | 08:04 PM
00MysticZ's Avatar
i will need a switch pannel i just ordered a LS1 Wet kit ( your brand )from you on thrusday or firday and you were our of both white and black bottle
i see a smooth bellows in a pic of your systems do you also sale those if so i want one as well
Derek
if you got teh bottles can you tell me if my kit and window switch have shippped yet
Derek Ayers
Old Feb 8, 2006 | 09:58 PM
terry s's Avatar
Hey Dave: there must be a misprint!!! I did not see the February discount listed on the FJO wideband you just sent me.
Old Feb 9, 2006 | 12:47 AM
ls1408cp's Avatar
no love for the carb looking guys
Old Feb 9, 2006 | 06:52 PM
Thanks for asking. Sorry we are not running discounts on them at this time.
Thanks
Dave
Old Feb 9, 2006 | 06:53 PM
Send me a pm letting me know what you are looking for. I will see what I can put together for you.
Dave
Old Feb 9, 2006 | 06:54 PM
We sell the NX gauge for 25.00
Dave
Old Feb 9, 2006 | 07:10 PM
thanks your friend
Sean Blanton
Sent you a pm.
Dave
Old Feb 9, 2006 | 07:12 PM
Derek
Derek Ayers
Your order left the next day aso you should see it any day now. Yes we carry the slp smooth bellows and the switch panel. WE do not have a special running on them at this time.I will be glad to help you with them the best I can though.
Dave
Old Feb 9, 2006 | 07:13 PM
No room for discounts on the FJO Items unless its passed down from FJO directly.. THey do have a killer product though.
Dave
Old Feb 9, 2006 | 08:32 PM
terry s's Avatar
Originally Posted by Nitro Dave's Nitrous Outlet
No room for discounts on the FJO Items unless its passed down from FJO directly.. They do have a killer product though.
Dave
Just kidding Dave. No complaints here.
On second thought you should tell FJO you have a good customer here that could use a nice discount and will split it with you!
Old Feb 9, 2006 | 08:51 PM
thanks for the help/PM!!
Dave is a great guy with great products at great prices!
cant wait to get my FJO controller and the other direct port stuff i am going to buy from you. this is my belated X mas!
Old Feb 10, 2006 | 03:28 AM
ls1408cp's Avatar
Dave
you have a pm
Old Feb 10, 2006 | 09:41 AM
Sounds like a plan... Now If they just go for it..
Dave
Old Feb 10, 2006 | 09:42 AM
Well Merry Christmas...
Old Feb 10, 2006 | 02:09 PM
Flash99's Avatar
Thanks Dave, I will be ordering today!
