Nitrous fill station ?s
You can get it for 3.50-3.75 from a speed shop!I have to check some other places, but what is the norm on buying it in bulk? And what size would be considered bulk?
IM looking into getting a station as well, How do you overfill a bottle?. I thought once it doesnt have room to fill anymore the nitrous flow will just stop or will it start to blow seals?.
the best place to gey nitrous is a company called AIRGAS they are the biggest compressed gas company in the world and their in every state.
you will have to setup an account with them and they will deliver but not to your home only to a buisness or a storage facility(mini storage etc.). they will send a sales rep to meet with you unless you walk into a store front and setup an account and charge you about $4-5 a month to rent the tank plus the cost of the gas. if you dont setup an account they will charge you $150-$190 for deposit plus the cost of gas.
if they send a sales rep to meet you he will initially give you a high price probably $140-175 but tell him you plan on purchasing at least 12 to 20 tanks a season and need to pay no more than $120 (or less(nitrous has a huge profit margin for them)) and the price will come down.
also make sure you ask for mother tanks with siphon tubes unless you like flipping 185lb cylinder on their heads but you usually get a couple more lbs out of mother tanks that you have to flip upside down.
now as far as pump stations go i have never tried the NX pump so i cant comment but of the small pumps that i have used the only one i would recommend for regular use is the NOS/holley nitrous pump its a bit of a dinosaur but its strong and you will need an air compressor to run it. not a big compressor but one big enough to run your usual pnuematic garage tools (impact wrench air hammer etc) something you would get at home depot.
OR
somehow get an old commercial refrigerator (restaurant) or a chest freezer the ones that dont have a refrigerated compartment they only freeze and drill a hole through so you can run a braided line from the mother tank to the tank inside the freezer and fill a tank that way. the freezer doesnt need to get below freezing as long as its in the low 40's and under it will fill a 10lb tank in approx. 45minutes or less as long as the freezer was at a cold temperature. with this method you can fill several tanks at once as long as you have enough mother tanks and braided line.
i prefer this method over the fill station and it will probably cost less than having to buy a pump station and compressor (air line, air dryer etc) aslong as you can buy the freezer at a used appliance store or swap meet because its quieter than having an air compressor and pump station buzzing away in your garage and if you over fill your tank you still have a saftey margin because the tank is still cold so you have a longer oportunity to purge the extra gas out of a cold tank that just came out of a freezer than a hot tank that just came off the pump and also i used to fill a lot of tanks at once and with the freezer i could fill upto 6 at a time and spend less time in a hot garage sweety garage in humid michigan summers.
if you guys have any more questions let me know i would be more than happy to help.
Called Airgas, and waiting to hear back, very pleasant, and despite being 100.1 miles from my house (and in another State) they said they service my area. Hope it pans out.
Thanks for the tip 1999 SS.
