time for me to spray
Old Feb 14, 2006 | 11:55 AM
ls1marine's Avatar
Default time for me to spray
ok i have heard alot of things about spraying on my car and the the thing i am not sure about is if i wanted to spray a 100 dry shot on my car the way it iswith my cam (cam in sig) do i need fuel injectors or a fuel pump
thanks
Bruce
Old Feb 14, 2006 | 12:27 PM
white2001s10's Avatar
What's your AFR now?
and what is your injector duty cycle showing on a scan?
I think you would probably be fine with just a 100 shot at this point, but it never hurts to check out the things above first.
Old Feb 14, 2006 | 05:34 PM
ls1marine's Avatar
ok how will i go about getting a scan on the injectors
Old Feb 14, 2006 | 06:50 PM
Hooper's Avatar
Any scanning software will work. Autotap or EFILive are good programs. I use HPTuners but you should check around your area for somebody who can help you scan your car.
Old Feb 14, 2006 | 06:53 PM
Hooper's Avatar
thanks
Bruce
I'm kinda in the same boat as you. I have a h/c car and I've got a NX wet kit about to go on. All my friends are telling me to upgrade my fuel pump to the Racetronix model. The logic is that it's cheaper to upgrade your fuel pump than have to rebuild your motor.
Old Feb 14, 2006 | 07:25 PM
ls1marine's Avatar
thats a good idea but the only problem is their are no tuners in san diego
