Dry Kits Users Please Step In…
Old Mar 14, 2006 | 12:10 PM
ConfusedGarage's Avatar
Originally Posted by Gabriel
Zex 125hp. Went from 106mph in the 1/4 to 118
Did you change injectors or the fuel pump? Just curious.
Old Mar 14, 2006 | 12:51 PM
Torque_Wrench's Avatar
Why are most people afraid of the dry system? To the best of my knowledge....a dry kit is actually safer isn't it? And it make sjust as muck power right?
Old Mar 14, 2006 | 01:05 PM
dirty2kTA's Avatar
i have ran 3 custom dry kits ranging from 50-150. the only thing that i liked, was being able to hide it. wet kits are more efficient IMHO.
Old Mar 14, 2006 | 08:58 PM
Robert56's Avatar
X-amount of nitrous/fuel equals same results wet or dry, with dry having a better safety margin. Most avoid dry because going over about 125hp then injectors come into play. however, HP Tuners has it set-up for easy rescaling of injectors and the cost for new injectors is small. Injectors and a base dry kit is still cheaper than a wet kit. I have done several dry kits 100/200hp single, dual and triple stage. I like it cause the chance of hurting motor is very, very slim. Just keep reading the posts and you will see the wreakage difference.
Robert
Old Mar 14, 2006 | 09:10 PM
Unstang's Avatar
I had a NOS 5177 kit with drilled jets on my '98 Z, it was good for +10 mph & -1.0 seconds.
Old Mar 14, 2006 | 09:12 PM
Beer99C5's Avatar
I am now going to have both wet and dry numbers done on my car with stock injectors and fuel system in the coming months, I will post the numbers when I got them. DynoTune Dry Kit (per my previous post this thread) and now a Nitrous Outlet Wet Plate system. After each system is commissioned (dynoed individually) they will be combined for a safe two stage. Will post numbers when I get them.
Old Mar 14, 2006 | 09:44 PM
Gabriel's Avatar
No. I may upgrade the injectors in the future.
Old Mar 16, 2006 | 10:23 AM
HPT BANDIT's Avatar
Come on, I know we got more people than this.
Old Mar 16, 2006 | 01:06 PM
AzzHauler's Avatar
From: Richmond, VA Where fast cars, well......are hard to come by.
Had a dry TNT kit before and loved it. 415/470 on 100 jets. Might have had headers then...don't remember, didn't have anything else but a borla and lid. Had a procharger episode, and now it's gone and I got another TNT dry kit going in for stage1 in a week or so. Still up in the air about stage2 being wet or dry or dp. Oh and a walbro intank w/ ghetto voltage booster and svo42# dealies.
Old Mar 16, 2006 | 05:08 PM
TA455's Avatar
I run a dry 100 shot with a Compucar kit. Engine is stock...no bolt ons...numbers are in my sig.
Old Mar 18, 2006 | 10:31 AM
CRL 01 SS's Avatar
NOS 5177 kit here, getting ready to see what it does with "no jet" now that I have the Racetronix PnP Fuel System and Racetronix 42 lb. injectors. The 5177 is supposed to be good for 135 rwhp, guess we'll see. Looking for around 550 rwhp with that. Once I get used to driving the car at the track on that I'll add another stage.
Old Mar 18, 2006 | 12:15 PM
  #32
CAT3's Avatar
Restricted User
First time no jetting, have fun. Split the Solenoids later when you want that second stage. GL.
Beer, get the two stages tuned by themself is a good idea, but also check it together, if not you might buy a new engine. The dry is going to force the injectors to work harder, which they could less fuel delivery from tapping the wet sides fuel source off the end of the rail (makes the #5, 7 cylinders a little lean).
Old May 14, 2006 | 10:20 AM
  #33
red fury's Avatar
NOS 5177 drilled out jets for a while was great..........now swapping out noids only to a NX IceMan PureFlow to run it progressive with the FJO unit. I have NO complaints about the DRY KIT!
Fuel upgrades are Lucus 42#injectors and a Walbro 255lph intank pump.
