FJO Wiring Diagram
Old Mar 13, 2006 | 08:03 PM
Johnny5's Avatar
Default FJO Wiring Diagram
Need a wiring diagram for the Single Unit FJO progressive controller. I will be using its WOT and TPS so I don't need the extras. I will also have a heater but no remote opener or purge at this time.
I was going to ask how to wire in the line lock but I guess it makes more sense to disarm the N20 when doing the burnout and then turn it on at the line.
Any of those pictures with pin outs on relays and where to fuse would be greatly appreciated.
Old Mar 16, 2006 | 07:43 PM
Johnny5's Avatar
no one has pictures of the newer single unit?
- FJO
- Arming Switch
- Trigger Switch
Where to fuse, relay pin-outs etc.
Old Mar 16, 2006 | 09:56 PM
02Vortech's Avatar
that is one of the easiest things i have ever installed- took me about 45 minutes since i have taken apart all of my wiring 4 or 5 times i know where everything was- very simple-
TPS
RPM
arm
power
ground- nothing much else....
Old Mar 17, 2006 | 07:57 AM
PAGregSS's Avatar
Here's one that Ricky had made a while ago. It includes the timing tuner, but I'm sure you can see how easily that can be eliminated from the wiring.
Attached Thumbnails FJO Wiring Diagram-fjo-20dual-20switch-20progressive-20with-20timing-20tuner.jpg
Old Mar 19, 2006 | 12:06 AM
Chopstix's Avatar
thanks
Old Mar 19, 2006 | 12:31 PM
Johnny5's Avatar
That one shoul get me close enough. I was going to hook up the other wire that would let me run two configurations as well. I think I've seen that one posted here before though so I'll go digging.
Old Mar 19, 2006 | 02:49 PM
PAGregSS's Avatar
I've got that one too. Here you go:
