Need Some Analysis Help
Old Mar 16, 2006 | 09:29 AM
Silver 00 SS's Avatar
Default Need Some Analysis Help
Alright guy i was looking at my best spray run and my best N/A run this is how it came out
NA_____________________150 Shot
2.034_______60' ET_______1.994
5.442______330' ET______5.408
7.731______ET@594'______7.577
8.234______1/8 ET_______8.038
89.45______1/8 PMH______97.61
10.609_____1000' ET______10.252
12.596_____1/4 ET________12.072
114.54_____1/4 MPH______127.08
Now my question is u think i started spraying after the 330'? what do u think i could pick up MPH & ET with a Stickyer tire?
Old Mar 16, 2006 | 09:44 AM
NXJeremy's Avatar
From the looks of the timeslip I would say either the system was activated somewhere between the 60' and the 33', or if you activated it out of the hole then the tires are spinning.
By going to a stickier tire you will see the biggest difference in the 60' & 330' ET/MPH.
Old Mar 16, 2006 | 10:09 AM
white2001s10's Avatar
About a second. You should be running right around 11.0 on the bottle using it for the entire run.
Old Mar 16, 2006 | 10:35 AM
hondo's Avatar
stickier tires will help you , 127 mph is plenty of power to go loooww 11's.
Old Mar 16, 2006 | 11:37 PM
Robert56's Avatar
A 150 shot should put you in the 10's with a Z06. Check out my sig for a 125 dry on only CAI and 315 BFG's. Keep at it, you have a beast on your hands once you get it to hook up.
Robert
