How to hook up a FPSS
Old Mar 17, 2006 | 04:46 PM
LS1FIRE's Avatar
Default How to hook up a FPSS
How do you hook up a Fuel pressure safety switch on a n/x wet kit? Were does it go? Is it electrical?
Old Mar 17, 2006 | 05:31 PM
terry s's Avatar
On a standard NX wet kit 1 wire to ground and the other wire to white relay wire (terminal 85)
The FPSS has to tee into the fuel line and it has 2 electrical connections. It is just a switch that operates by fuel pressure.
Old Mar 17, 2006 | 10:52 PM
daryl2cb@yahoo.com's Avatar
Are you running a window switch? If so the wiring is different. get in my sig, under nitrous look at the saftey pic, you can see how mine is setup
