Any dry kits rated @ wheels?
Just be sure your AF is good, the system is working properly....and jet to desired HP. Differences of +/- 10hp or so with a specific jet size are negligable and have no real meaning IMO.
The manufacturers ratings are there just to get you in the ballpark. many things will affect the actual power recieved from a given jet size. As long as your kit is capable of making the range of power you are likely to use...your good to go.
as far as the bigger shot (rating) being more dangerous...not at all. 100 hp is 100 hp regardless of the jet size or what the manufacturer rated it at. Again...just be sure your operating parameters are safe.
When I was running dry...I would have a bunch of blanks...and just drill them out and mark them for what actual RWHP was on MY car.
Good luck!
