How to??
Use a t-fitting to split the nitrous into two differnt lines then put a solenoid onto the spliced end and run another nozzle into the intake- You can use an FJO mini progressive out their two stage window switch- I beleive HSW sells a two stage conversion kit for like $160 and the mini progressive is $200 and their basic 2stage W/S is i think $140 if memory serves right
on the wet kit one is a fuel solenoid i dont know how they differ from each other but i havent heard/seen anyone using a fuel noid for nitrous..... i would just do it right and run a second n2o noid
Originally Posted by bigpappasz28
this is the dry kit two noids both for nos
