bogging when launching with juice
Old Mar 21, 2006 | 06:18 PM
jgarfiaz's Avatar
Default bogging when launching with juice
i recently went to try out the new cam patriot performance 226/226 585/585 112lsa and i managed a 12.8 but when i used the nos 100 shot the best was 12.4 it seemed to bog each time i used it. before i would get a 1 second diffrence on nitrous. i launched it at 3000 as soon as it hooked i floored it and i bogged a bit then took of really strong. same thing each time. my trap speed was 118 60 foot was 2.05 about on all. what could be causing the bogging.
Old Mar 21, 2006 | 07:06 PM
walker94z28's Avatar
is it wet or dry, I had the same issue with my new direct port and the guys here told me to upgrade fuel sys, cause the kit was pulling the rais dry. I now have a stand alone setup but dont know yet if it fixed it.
Old Mar 21, 2006 | 07:36 PM
TINKRD's Avatar
mine too has done this before. Wet kit here.
Old Mar 21, 2006 | 08:13 PM
TN94Z's Avatar
Wet or dry kit? Is it set up to come on at wot?
Old Mar 21, 2006 | 08:24 PM
TINKRD's Avatar
mine is wet, TNT kit, WOT switch, plus a window switch, 3400-6800
Old Mar 21, 2006 | 08:35 PM
mine is just a d.p nos 08301 with a w.o.t swithch.
Old Mar 21, 2006 | 08:59 PM
jgarfiaz's Avatar
a wet kit wot switch with no window switch i wanted it to spray off the line could it b timing or fuel system
Old Mar 22, 2006 | 06:01 PM
ttt...
Old Mar 23, 2006 | 12:53 PM
SprayedLT1's Avatar
Do either of you have a fuel pressure safety switch? I have heard of people having bogging problems when using the fpss too close to the fuel solenoid. The bog happens when the fuel solenoid opens and the fuel pressure dops quickly, causing the fpss to cut the solenoids off. Once the fuel pressure builds back up, the fpss allows the solenoids to open again.
Old Mar 24, 2006 | 11:45 PM
Dune-LS1's Avatar
^^^^What he said^^^^
Old Mar 25, 2006 | 09:22 AM
No safety swithc, but I was told that my dp kit was sucking the fuel rails low and that was what caused it. Is that still feezable without the fpss.
Old Mar 25, 2006 | 08:51 PM
hondo's Avatar
fuel pressure?
bottle pressure?
what plugs are you running?
Old Mar 26, 2006 | 07:06 PM
I ran my car today with the stand alone kit and NO MORE BOG.. The car ran strong and I only made one pass with 750 pounds of bottle pressure and it went a 1.46 60" and 6.6 @ 102. Thats a 2 mph drop on my times but it must be due to bottle pressure. I got it up to 950, but they were bracket racing and I couldnt get a pass.
