A few pics of my finished single plane DP
Old Mar 22, 2006 | 08:19 AM
SMKN TA 95's Avatar
Default A few pics of my finished single plane DP
As some of you may remember, this is the single plane intake that Dave and Nitro Daves did about a month ago. Once I recieved it back from him, I went ahead and put my dual purge solenoids on, and bent the lines and such to feed them. I also finished the wiring so it will work in conjunction with the plugs I already have in the enginecompartment.
For the purge I used 2, 175 hp CF nitrous solenoids. I was going to use the ones from NX but I got a deal on these through ebay direct from CF. I made the bracket and bent the lines one day after work. Being that it was my first time bending/flaring stainless.....I am glad that I had extra tubing Once I figured out the proper way to get the right bends and the flare, it went very easy
Picture of purge setup
A little blurry as the camera wasn't set up right
Rest of Intake and wiring
And heres a picture of the car.......Anyone that has dealt with Eastside may remember this car.....Noyzee might........ Although the car has undergone quite the transformation since it was bought late last fall and now resides in IL.
Old Mar 22, 2006 | 08:30 AM
HowellSoccer88's Avatar
Damn good looking setup and car!
Old Mar 22, 2006 | 08:46 AM
SMKN TA 95's Avatar
Thanks
Here is what the hood looks like after paint (The stripes are painted on and not decals )
Old Mar 22, 2006 | 09:02 AM
Looks even better now that I can actually see it...definitely sharp!
Old Mar 22, 2006 | 09:10 AM
NXJeremy's Avatar
Good job on the purge setup, looks like you spent quite a bit of time making sure everything was symmetrical (and it paid off, looks great.). Were you going to mount the bracket holding the two solenoids to a point on the intake, or is the stainless hardline the only thing holding them? Either way, it all looks great.
I like the car too, those stripes look good.
Old Mar 22, 2006 | 09:20 AM
SMKN TA 95's Avatar
I did spend some time trying to make sure it all looked symetrical and even
As for holding it up, the stainless line is doing that right now, but I may make a small bracket the ties the solenoids into one or 2 of the valley cover bolts. Not a big deal at right now, plus those solenoids dont weigh too much at all either.
Old Mar 22, 2006 | 09:41 AM
Big Geek's Avatar
Damn!!! Man I tell ya Nitro Dave's work is so sexy it ought to be considered pornography for LS1's!!!
Jim C.
Old Mar 22, 2006 | 09:47 AM
TN94Z's Avatar
That looks good. Very nice setup.
Old Mar 22, 2006 | 11:05 AM
NXJeremy's Avatar
[QUOTE=Big Geek]Damn!!! Man I tell ya Nitro Dave's work is so sexy it ought to be considered pornography for LS1's!!! QUOTE]
That is one of the best quotes I've ever seen
Old Mar 22, 2006 | 04:34 PM
1MEANGTO's Avatar
That looks sweet !!!! Now you need to get it on the motor!!!
Old Mar 22, 2006 | 04:59 PM
99SLOWC5's Avatar
I love how every bit of the install is symetical
Awesome work
JEFF
Old Mar 22, 2006 | 08:42 PM
TwoFast4Lv's Avatar
Damn nice setup!
Old Mar 22, 2006 | 08:52 PM
Robert56's Avatar
Very trick set-up, nice. Hey, does Dave do the actual plumbing on all these intakes? or someone that works for him? Whoever, is doing nice work.
Robert
Old Mar 22, 2006 | 09:19 PM
Somebody09's Avatar
Awesome setup! I was thinking about doing dual purges too.
I have question though:
WHERE DID YOU GET THOSE CONNECTORS!?
The largest I can find are for 3 wires
I tried Waytek Wire and they have ones for 4, but preassembled, and I don't want that.
Old Mar 23, 2006 | 12:33 AM
ls1408cp's Avatar
looks cool love the connector idea
Old Mar 23, 2006 | 01:04 AM
CAT3's Avatar
Restricted User
I been looking for the same connectors, 6 wire flat, although I'd prefer a 6 wire, double row. Either or. Setup looks sweet.
Old Mar 23, 2006 | 01:22 AM
NOSjohn's Avatar
Restricted User
I buy mine from koskowskimotorsports.com/kms. Decent prices too.
Old Mar 23, 2006 | 06:42 AM
Somebody09's Avatar
OMG I love you! Thanks so much! And they're so damn cheap too!
Old Mar 23, 2006 | 08:10 AM
SMKN TA 95's Avatar
I got all of mine from Summit racing (www.summitracing.com) They are actually much cheaper than the ones on the site that NOSJohn posted. You can get a pack of 5 6-pin housings (both sides) for $6.95, then buy the pack of pins (20 pins male/female) for another 6.95 and your set. Much cheaper and you get alot more. You can get 2-pin housings on up to 6 pin housings.
Old Mar 23, 2006 | 08:12 AM
227Hawk's Avatar
VERY VERY NICE!
Hawk
