75 dry shot
do i also have to descreen my MAF?
Matt
and she held up fine but now the motor has been pulled to go bigger and better and everything looked great. little worn out on the rod bearings and 1 burnt plug but that is normal for a 650+ RWHP stock bottom ls1 If you wanted to stay safe I would say a 125RWHP shot all day with colder plugs and a little richer on the tune (if you want to be real safe) Some say pull some timing and others say 125 there is no need so i guess thats up to you but If your running it rich and you have the plugs I would say let the timing stay how it is.
I had 42lb and on the 240 shot it was at 14.4 for the duty cycle (havent done the % conversion)
