Fuel Pressure safety switch
Old Mar 23, 2006 | 06:46 PM
formula8r's Avatar
Default Fuel Pressure safety switch
what is the normal setting for a fpps? mine came set at 35psi, i know ur supposed to adjust the set screw, how the hell do u know when ur at the right psi? also i have a dry system and was wondering what fitting guys were using and how u get a shrader valve removal tool????????
Old Mar 23, 2006 | 07:06 PM
98redorangeta's Avatar
As for the tool i just used the same one as i use for valve stems on tires. THe fpss just adjust it till what ever your using it to turn off turns off then back it down a hair.
Old Mar 23, 2006 | 07:19 PM
formula8r's Avatar
thanks man
