How long does BH take?
Old Mar 24, 2006 | 08:12 PM
HowellSoccer88's Avatar
Default How long does BH take?
How long should the bottle heater take to get pressure around 950. I am using the 300 watt CFN heater with pressure switch. Prior to heating pressure was around 600. Its about 40* outside. What do you think?
Old Mar 24, 2006 | 08:18 PM
Robert56's Avatar
I have had it take upto an hour. It just depends on ambient air temps. I will say that a 300 watt heater will heat a bottle in 80% of the time it takes a 240watt heater, at what ever air temp.
Robert
Old Mar 24, 2006 | 09:38 PM
227Hawk's Avatar
So is this a 'math' thing?? If you want your heater to 'UP' the pressure
quicker then a bottle heater is a good investment.
Hawk
Old Mar 24, 2006 | 09:41 PM
TN94Z's Avatar
mine used to take around 30 minutes or so, but that was when it was a little warmer outside
Old Mar 24, 2006 | 10:26 PM
oange ss's Avatar
about 20 min for mine, from 45 deg to 1000 psi...same heater setup
Old Mar 25, 2006 | 12:39 AM
thanks guys
Old Mar 25, 2006 | 12:40 AM
Turo's Avatar
That's one good thing about FL, the weather is our bottle heater .
