Dry/Wet & Stock fuel pump
I was the one asking about the dual stage dry/wet combo. when i do this do i need to upgrade my stock fuel system? like a pump, or bigger injectors?
Yes definitly upgrade the fuel pump. If you can afford it my suggestion would be a racetronix for the dry and motor. And a Standalone fuel cell for the wet.
You could then run race fuel in the wet shot and really help on the protection factor. You can set up your stages and just increase the shot sizes as money allows.
Hawk
Hawk
I have a 2 stage system with the stock fuel system for now. I run a modified 5177 kit as the first stage=100hp dry. Then I have a modified NX MAF kit for the second stage =50hp wet. No problems with fuel pressure. When I get the Racetronix pump I will go up on the second stage.
Originally Posted by TRYTHSS
what is modified with your 5177 kit? what kind of times do you run with the dual stage?
