View Poll Results: what shot to begin with
100 shot
15
9.04%
150 shot
25
15.06%
175 shot
6
3.61%
200 shot
36
21.69%
225 shot
7
4.22%
250 shot
77
46.39%
Voters: 166. You may not vote on this poll
408ci Directport
Old Apr 17, 2006 | 12:45 AM
1fstGM's Avatar
Restricted User
Ok, thanks rick! Is that the plug part number? NGK?
Old Apr 17, 2006 | 07:44 PM
BadAssFast's Avatar
It is an NGK spark plug. Cold one too.
Old May 7, 2006 | 10:18 PM
CAT3's Avatar
Restricted User
I assidently hit 200, but meant to say pill it for kill, 300. Use your controller to limit the amount it flows, you can creep it up by trial and tune. Run it on a 150, pull plugs, read the AFR, adjust...run it 150 if its right, then move on up to 200 and repeat. Before you know it, you'll be shooting the moon. Ok, seriously though, after having gone the DP route before, I dont like ******* around changing jets all the damn time. I would pill it and controll it as mentioned. I would check the tune, and probably start of 200 after a 1st gear lockout. GL.
Charlie
Old May 8, 2006 | 10:16 PM
Sn8ke_Eater's Avatar
Just spray a 1000 shot and call it a day. lol
Old May 10, 2006 | 01:01 PM
BadAssFast's Avatar
No doubt...after running a 200 shot for several weeks with the 408...it's just a beginning. Bring it in soft with a prog perhaps or dual stage it or both...certainly what i'm coinsidering....but do it (like it was said earlier) BIG!! 250-300 if it's got the ham for it!!
Old May 13, 2006 | 03:53 PM
krazy4's Avatar
250 shot!!!!!!!!!!!!!!
Old Sep 2, 2006 | 03:30 PM
00Vette's Avatar
I'd also start with a 200hp shot and work my way to the 250hp shot. And if your motor is forged I'd personally spray more than that.
My big picture plans are to build a forged 400+ ci motor and spray a direct port 300hp shot into it.
Old Sep 2, 2006 | 10:05 PM
JUICED96Z
Guest
Posts: n/a
What? No option for 400-500 shot?
As once stated if its a DP then go big or go home
Old Sep 2, 2006 | 10:25 PM
pewter 01 SS's Avatar
hhha thats a big *** shot.. better be a two stage if you try that lol.. for now im going to go with a 200shot in the directport and either a 100 or 150 shot with my wet kit..
Old Sep 3, 2006 | 01:47 AM
SILVERZZ28's Avatar
Originally Posted by Rick@Synergy
Start at a BR7EF, work your way from there.
Rick
those are like glow plugs (projected tip plug) sitting in the chamber
Old Sep 3, 2006 | 08:39 PM
JUICED96Z
Guest
Posts: n/a
Two stage for sure, of not a 3.
75 first, 175 second, 250 third. That would put you right at 500hp shot (depending how rich you go and all I guess)
That would also be a lot easier on the engine then two BIG hits...
Kinda a small hit off the line though when compared to a 500 hit.
Old Sep 4, 2006 | 12:42 PM
  #32
Noyzee's Avatar
8 second mod
haha, do i have the intake for you!!!!!
Old Sep 23, 2006 | 10:32 PM
  #33
tuff's Avatar
8 SEC SLOPPY SHOT!!!
Originally Posted by 1fstGM
So what plugs are you 200-250+ shot guys running?
Id go with a ngk 8 just to be safe and if it feels like the plug is to cold you can always go with a hotter plug.
Old Sep 24, 2006 | 06:23 AM
  #34
charlie c5's Avatar
While your getting dyno tuned start with a 100, then bump to a 200 and keep going until you, the tuner and the car is happy. I have almost the same set up as you, and I'm lookinng at a 500 shot. I do have a few more tricks up my sleeve. But with the right tune you'll be fine with at least a 200... Have fun and "JUST SPRAY IT!!!"
Old Jan 2, 2007 | 05:30 PM
  #35
LostCauseZ06's Avatar
Originally Posted by Airwolf
When I think "check" I am referring to A/F ratio. This will let you know everything is working fine. Doing a large shot and not knowing your A/F is risky to me. That's just me. After I know my A/F is good, (or if not why) then other things fall in line to check. I personally record a 3rd gear hit with my LM-1 and see where I am at. This gives me a 5 second run under good load and I can see if my fuel pressure is set correctly and the system is working well. This also takes traction out of the equation and gives a nice run.
lol i dunno about you but i spin in 4th hitting my 200 shot on the freeway
Old Apr 21, 2007 | 08:51 PM
  #36
stangeater01's Avatar
i shot a 150 on occasions on my old set up most 250 then grabbed the second stage 100hp this was on my old set up 408 check my cardomain site
Old Apr 21, 2007 | 09:30 PM
  #37
Z284U2TRY's Avatar
When I started on my directport they said the kit could not go below 200. Cold fusion direct port.
Old Apr 22, 2007 | 01:34 AM
  #38
GueSS Who's Avatar
Rick
Those plugs are the ****. Have seen really big power on those plugs.
Old Apr 24, 2007 | 09:38 AM
  #39
STRIPSTAR's Avatar
Originally Posted by Noyzee
if you know how, reading a plug is the most accurat way to tune.
the af monitors are good, but plugs dont lie. lol
Brad, as a new mod, why dont you do a plug reading sticky with a few pics. That would be helpful.
Old Apr 25, 2007 | 11:18 AM
  #40
SILVERZZ28's Avatar
Yeah until it pops one
With that setup he needs to start with a R5672A-9
