is this safe
Old Apr 6, 2006 | 06:34 PM
99Z28camaro's Avatar
Default is this safe
i was thinking about putting a 75 or 100 wet shot on my 99 z28 but it has 140000 miles on the motor but still runs really strong i have had no problems with anything but was wondering if it would hurt anything and still be safe?
Old Apr 6, 2006 | 06:57 PM
Matt@HSW's Avatar
You should be okay. You could always do a leakdown test before you sprayed her to see what shape the motor is in. If you wanted to play it very safe maybe upgrade the fuel pump.
Matt
Old Apr 6, 2006 | 07:05 PM
thanks for the reply
Old Apr 7, 2006 | 10:15 AM
Nitro Dave's Nitrous Outlet's Avatar
I agrere that it should be ok if the car has been well taken care of and still has a good leak down and compression test. However that is alot of miles. I would not put nitrous on it unless you are ready to expect the worse. No one can give a for sure answer on that.
Dave
